spinzola
New member
how do i recieve a flash code in a 81 vette with a 5 pin connector? need help fast. thanks
HI back again. Got car fixed.Had to jump the 2 pins all the way to the left in dlc connector.Code 51 came up.Found connector at ECM to be clean and tight.The prom was not tight in ECM.Snapped in prom and all is fine.how do i recieve a flash code in a 81 vette with a 5 pin connector? need help fast. thanks
