While sitting in bumper to bumper traffic yesterday (behind a black pick-up) I noticed one of my fog/driving lights was out. Anyone know where I can get a replacement? How hard are they to change out? I looked in my current Eckler's and Mid-America catalogs and couldn't find them.
I went through the engine compartment. I opened the hood and went in from the openning between the hood and the car. You need to reach down to find it. Once you find it, you can unplug the bulb like the head lights and replace it. Good luck.
if you have a fat arm the best way is to raise the hood and head lights,remove the black plastic cover from the head light and reach down and turn the bulb holder CCW to remove. also never touch the new bulb with your bare hands because the oil from your skin will etch the bulb glass when it gets hot and cause it to be not as bright aspossible. to get the head lights to stay open turn them on,after they come up turn the switch to parking lights and the head lights will go off but will stay open.
If you have ramps or a lift it is fairly easy to remove the inside fender cover to get full access the the lamp socket. This way I could see what I was doing and not squeeze my arm too much.
I concur with the recommendation to get the 885's above (go to any decent auto parts store). For about $7.00 each, you get tremendously better light.
There is also no need to take the car apart. I did mine in the parking lot at the store after I bought the bulbs. Raise the headlights, turn back one notch to keep them up but off, make sure the fogs are off, and raise the hood.
You can see the back of the light -- reach in and it's a quarter turn.
You may also want to think about cranking them up a bit from the factory setting (not so high that you blind opposing traffic, though) -- use a Torx (tm) screwdriver at the side of each lamp from the front.
I just took my 99 to the dealer for an oil change and the steering column recall and made an off hand remark that the fog lamps were not working. (Just bought the car).
Cost to replace the two bulbs and labor $80.00!!!!!. That's more than the original cost of the option.
Guess I need to learn to keep my mouth shut and come here first when there is another problem!!
Well this evening I had the same expereince! While driving home form work I noticed one of my Fog/driving lights was out. I noticed it in the rear of a black car in front of me! Go Figure!
