M
MagikDraggin
Are the fog lites on a C5 adjustable as far as being able to raise the beam angle?
There is a torx screw adjuster on each lamp. Look at each lamp, at around the 11 o'clock and 1 o'clock position you will see the opening to get to the torx screw.MagikDraggin said:Are the fog lites on a C5 adjustable as far as being able to raise the beam angle?
Really? I'll have to get back out there and check that out. Thanks for the tip.MAC5 said:There is a torx screw adjuster on each lamp. Look at each lamp, at around the 11 o'clock and 1 o'clock position you will see the opening to get to the torx screw.
Have the lamps turned on and shining on your garage wall or door, you be able to see the beam change up/down.
MAC
MAC
