Johan
Is there some special trick to remove the differential crossmember? I have removed the bolts, and tried to pry gently with a crowbar, but it doesent move... Should I just throw in the usual exessive force and bad language?
2)
I have a replacement frame for my old 69 frame. The new frame is supposed to be 69 or 70, it is a manual frame since the transmission crossmember is not bolted, but it does not have the clutch axle bracket? Doesn't look like there was one either because there are no signs of any welds. Not a big problem for me as I'll just have to weld the old bracket there, but how come it looks like this?
/Johan
2)
/Johan
