T
Tbird
The question is in regard to a C2 1964 frame.
I had my trailing arms taken off for replacement. When they removed the old arms they found some rust in the area where the arms connect to the frame. Would I need to replace frame or can the frame be repaired in this area? I'm told either way the body would need to come off. If the frame is repaired would it be as strong as new or only a temporary fix? I am getting mixed information and need some help from the experts so I can make an informed decision. Any guidance you can lend woud be much appreciated. I look forward to your response.
Thanks,
Chas
Thanks,
Chas
