...then you have the vin at the windshield
>>> Mine is not the same as the one on the frame(EX5014 vs 1000043)<<<<
and then on the door tag...sometimes they have a tag with the vin on the underside of the console door and sometimes on the underside of the rear compartment door lid.........then they usually put a build sheet with vin on the fuel tank[usually glued to the rear of the tank where the straps wrap around it]...then,they usually stuff a build sheet with the vin and codes inside the hollow portion of the front k-frame assembly,where the front spring slides through
>>> Build sheet lists both vins see link<<<
http://www.sirgalahad.org/tyler/prototype/43buildsheet.jpg <<<
