Front and rear Corvette badging emblems
Pseudomind
Jacksonville, FL
2002 MY Roadster
Has anyone ever changed theirs. I am toying with the idea of going with these stripes and I believe the black emblems might go better.
They are held on with double faced tape. The front has alignment pins too. Both go for around $30 each! :crazy
:bang
:bang
Have you chnaged any. I know they have to be carefully heated with a heat gun to remove, What I do not know is if there are any other tricks to use to make it easier and less chance for errors (messing up tht paint)
I have not changed any but I do have a newer front fascia I have to put on. It did not have the badge but the double faced tape was left behind. I ended up using Industrial or high strength Goof Off to break it down. Kind of was a PITA but worked and did not bother the paint. I use it all the time when I detail cars on the tar... Seems the longer they are on the harder they could be to remove.
I have also herad of people using fishing line to remove the body side moldings then remove the tape residue. My car did not have BSM's so I did not have to remove mine.
A heat gun or hair dryer may work to loosen then up too...
:bang
