JimVette
What will cause the front brakes only to lock up. I have a good idea but would like other inputs. Let me explain what happened.
I was coming home from a car show Saturday and through my rear mirror I spotted a Camaro pace car coming up behind me in and out of traffic. So I figure he wanted to play, I turn A/C off, radio off (antenna down) and ASR off. Well we never could get side by side but about 50 mph I started to feel a vibration in the steering so I pulled into a side street to stop and see what the problem was. There was a little smoke coming from the drivers front brake. I open the hood and discovered smoke coming from the tire and the front drivers side brake is locked up and it appears the right is also locked but not smoking. I cannot get it to release so I shut it down and am ready to call AAA. I start it up to move it into a parking lot and the brakes are released but in order to get brake pressure I have to pump it several times to stop. I never got a brake warning light and the fluid is normal. By the time I get home the brakes seem to be normal with a little more pedal travel. The ASR is only rear only, the vacuum booster I think should not cause it loose pedal pressure (to the floor). Besides the brake lines colapse or master cyclinder failure I can't think of any else. I have a GM service manual but this problem I could not find in it. '92 ZR1
