vsg914
Like the title says, the drivers front caliper jumps over the retaining pin. The pads are installed correctly, and the spring clips are installed on the bottom of the pad. I've replaced pads and pins (multiple times). I can see no physical damage to the caliper mount and the rotor runout is minimal. Any help as to why this is happening is much appreciated.
Thanks in advance.
Thanks in advance.
