mlm0
I have 89 vette, and am going have a front end alinement done. does the rear end need alined also.
93Rubie;1123216.......... to do a proper alignment the rear is set first then the front. Do a 4 wheel.[/QUOTE said:As '93Rubie' suggests...... the rears are aligned first..... vettes require a four (4) wheel alignment. If the shop uses 'HUNTER' alignment equipment, that is a good sign, but a competent tech is required to operate the equipment.
If a tech offers a 2-wheel alignment, go find another shop.
