V
Vette66AirCoupe
My '66 sits too high in the front. I can stick my flattened hand in under the fender and reach straight in and go right over the top of the tire. The car has KO's on it with 205RX15 tires. I've tried to see if the coil springs were seated at the top but damn if I can tell, couldn't get a glimpse from any sight angle I could attain. I do know they are not seated at the bottom but if memory serves me correctly regarding some other discussion on this topic the bottom doesn't matter. The springs have been on the car for over three years and probably around 5,000 miles so I don't think they are going to come down any more on their own. I have no idea if they are the correct springs for the car. If I simply replace the springs I'm afraid I'll end up with the same result. A mechanic recently mentioned the possibility of cutting the springs. Considering the aerodynamics of the mid-years, having the nose up to start with makes the ride seem awkward with the front end rising so much more under acceleration. How should I proceed?
