lex luther
I am having a problem with vibrations (which is shaking the hood excessively) starting at 65mph. I have had the front end checked and the mechanic says everything is in spec and aligned. Went to Discount, and they replaced free of charge the 315's I had on the back to go back to stock 275s (Goodyears). I replaced the rear wheels with new 9 1/2 stock configuration. I have 85k on the vette, and it had previously been smooth, no vibration or noise at much higher speeds. The front tires are only one year old, and all have had balancing checked and rechecked. The mechanic indicated that this is to be expected with the age of the rubber bushings on the front end, but otherwise is fine. NOT, I do not like driving it with all the hood vibration and chatter. Anyone else encountered this who can target a fix?
