front engine oil leak
  • Thread starter Thread starter Robin7TFour
R
Robin7TFour
HELLO, a co-worker here at walt disney has a 93 ruby. he has an oil leak at the front of the motor . he has looked and looked,but can't locate the leak. any suggestions?
is this a common problem with the 93's?
thank
robin
Sounds like the front crank seal. I just went through this. Nothing but bad news if thats where the leak is. If you take it in to be done it's a $300 plus job. If you do it yourself you have to take the whole front end of the engine off. Good luck to your friend though.
Jedi
Yep thats what happened with mine.
robin [/B]
Your friend can get some oil dye at a GM dealer, add it to the oil and drive a while, then go back to the dealer or find a shop with a black light where it can be put up on a lift to pinpoint the source of the leak. Usually works great.
Terry
