G
Geek's 65
Don't waste any time or money on a spring compressor. The easiest, safest, and least expensive way is with a thick threaded rod. Find yourself or purchase a length of threaded rod 5/8" or 3/4" by 30" long.
Remove the shock absorber, and replace it with the threaded rod. At the bottom, I use a thick metal plate about 4" square, and at the top, a few thick flat washers. After threading a nut at the bottom to keep the plate in place. tighten up the nut at the top, while paying very close attention to any upward movement of the lower A-arm.
The minute it starts to rise, you may then completely remove the nut that hold the top ball joint in place, and then all that you need to do is get it out of the spindle, ( a pickle fork, or a few choice blows with a MAN'S hammer ) will usually do the trick. Now unscrew the top nut on your threaded rod and watch the lower a-arm sink low enough to remove/reposition or do what ever else you wish to do with the spring.
No chains or anything else are needed, since even in any worse case scenario, the rod will keep the spring from flying across the garage floor.
Stepinwolf
Been here. Done this. So much better than a spring compressor for all the reasons stated earlier. The threaded rod gives you full control of the spring as you let off the tension and like Stepinwolf says, if it does decide to try and escape on its own - the rod stops it and the only harm done is a quick shorts change.
Geek
