I'v been through the process
I have went through the process of replacing my complete front suspension with the Vette Brakes & Products transverse front spring, and I am thrilled with the upgrade. Our mid-years are Americas premiere sports car, but we have a tendency to forget that the suspension, and drive trains, are 40 year old technology.
When we build or restore a Corvette to have it go through the judging process, everyone agrees that it be kept in it's original condition. However for the regular " driver " type of ride that the majority of the vehicles are used for, there is no logic to keep maintaining any of the braking, steering or suspension systems that are outdated, and in many case outright dangerous to use.
Were the upgrades not available, many of us would complain about the situation, but now that these parts are on the market, not to mention, very affordable, I don't understand why more hobbiests do not profit from the technology
As far as the front spring conversion itself, the two things, other then a smoother ride, that most impressed me was the ease with which I can change the spring rate, and the adjust-ability of the ride height.
Normally, when one changes the front coil springs, a choice must be made as to exactly what spring rate must be used, that will resemble as closely as possible, how you want the car to behave. The second issue is the ride height. Choose the wrong springs, or " God forbid " receive a set that when installed are not " PERFECTLY MATCHED " and I promise you , you will not be a happy camper.
By replacing your front coils with the Vette Brakes front fiberglass spring conversion, it will guarantee you that you will never find yourself in this type of situation. The reason is in the way they are attached to the frame. They are mounted using a bracket that serves to adjust the spring rate by simply moving the attachment point to four different settings. By doing so you can soften the ride, or make it as harsh as you would like it to be.
The second thing we should consider is the ease with which the ride height can be adjusted. Those of you who have had to replace a metal transverse spring under tension, will certainly appreciate the advantages of the front fiberglass spring. The reason is because once it's properly installed, and the weight of the car is taken off the spring, the spring itself is no longer under tension. The spring bolt that connects the spring to it's support is completely loose, and one can use a wrench to turn the nut, one way or the other to raise or lower the car to whatever height adjustment is needed.
You might want to try adjusting the ride height with a set of coil springs and see how far you will get.
In closing ( sorry for the length of the response ) I have driven many mid-years during my life, and I must confess that the ride I now have with the car, since the suspension was replaced is something I will never again live without. I am so impress with the advantages that I will never go back to the 40 years old technology, for the sake of correctness.
Stepinwolf
