G
groovyjay
stepinwolf said:As far as adjustably of the spring rate, and the ease with which you can raise of lower the ride height, the use of the transverse fiberglass spring, will by far make these tasks much faster and easier, then with any type of coil/over suspension.
regards
Bob
a.k.a. Stepinwolf
In real life most of the C2 drivers will set their suspension once to the desired height and set the spring setting to the one they like the most (Race, hard or semi-hard.). I like to play with the springs and setting a lot, I found that with the big block I still like to have the spring in the softest setting and the suspension as low as possible.
As far as the front suspension tuning goes I like the coil overs alot more than the leaf spring. The leaf spring is very limited in terms of adjustability. Although it provides couple of different settings for most people to find their "optimal" settings, with the double adjustable coil overs you can play with both the compression and rebound by just clicking the knob, takes less than a second to do it! And if you really want to get to it, get few different sets of springs that you can use for different types of driving. I have different lb. rated springs for street and open road track.
But like I said, most people will just buy the kit have it installalled and alignments done and forget about it.
