bwstreaker
I cannot get the tachometer in my 1968 to function properly and would appreciate help. I have the original gear drive tachometer in my vette which bounced at low RPMs. I checked the cable and it appears OK. The cable end is also not rounded. I have replaced the side distributor gear and installed an angled cable connector at the distributor so the cable is not bent. After all this, the tach simply bounces between 0 and 500RPMs even when engine speed is increased. What do I need to try next?
