FS: 1111194 tach-drive distributor, 67-68 327ci/300HP - $175
San Jose, CA
1970 LT-1 Resto-Mod, 1977 L48 (parting out)
From what I have found this is correct for '67 or '68 327ci 300HP Corvettes. Somehow it found its way to my '70 LT-1! It was removed when my car was upgraded to EFI and has been stored. Looks to be in excellent condition. Play seems reasonable, no noticeable gear or points "octagon" wear, mechanical advance seems to move properly. Spare vacuum advance can included, not sure which if either is original. The mounted one has a hex shape on it, the spare is just round.
Two things I need to check tonight: Need to verify that the tach drive is spinning. Date is 1967, but can't read the rest in my photo.
Asking $175 + actual S&H. Every other one I've seen listed has been $200-250 so I'm going lower for a quick sale!
I haven't been very active here so far but I'm a 10yr CorvetteForum member.
Tach drive spins smoothly.
Date code is 7 B 6. That's 1967 and I believe the rest means February 6th.
