FS: 1958 Rochester Fuel Injection system & distributor- Rebuilt
silverblue
New member
Detroit, mi
61 Red/White cove
1958 Rochester Fuel Injection unit 7014900R 290 HP, Serial number 1932 & Correct Delco-Remy FI distributor 1110914 Serial 9 H 26. Both rebuilt, alot of $$$ spent, comes with receipt showing the following work was done;
Replace Inner Drive Cable
Replace Cranking Signal Valve
Replace 3 defective nozzle blocks
Resurface diaphragm covers to prevent/eliminate vacuum leaks
Plug & seal side of fuel meter
Resurface internal linkage assembly
Install anti hydrostatic lock solenoid
Correct choke link rod
New primary return spring
New fuel meter shield
Replace thermostat, housing & gasket
New large base plate gasket
1110914 Distributor received a NOS dual window cap as part of its rebuild.
FI system complete with the exception of the air filter housing.
PM or email with any questions & to see more than 40 photos.
$9,999
