2010 ZR1 Cyber Grey / Ebony & Dark Titanium
located in Cocoa, FL
3543 miles on odometer
#1571 of 1577 made in 2010
Asking $81,000 no trades considered
Email at reid dot ryan dot c at gmail dot com (replace dots and at) or PM
Serious Inquiries may call at Three21 Seven Nine Four 45Two Seven
This has been a show car for my wife and I. Purchased in Fort Lauderdale and trailered home, this car has always been garage kept. Interior and exterior are immaculate, maintained with the best from Adams, Zaino, Mothers, etc. This car won top C6 at the Corvettes on the Pier in St. Petersburg in both 2011 and 2012. It has done parade laps before the Rolex 24, however it has never been autocrossed, drag raced or tracked. I can provide full inspection on lift at my home or you are welcome to arrange inspection at a local mechanic. There are a few interior and exterior mods, all very tasteful and listed below. Electrical for Mild2Wild and Vettebin 12v outlet are expertly done, nothing in the stock harness has been harmed in any way. In service 1/22/2011, factory warranty good through 1/22/2014.
Modifications:
APR Carbon Fiber Diffuser with Custom LED Reverse Lights
(Also have stock Diffuser)
Custom LED Backup Lights
APSIS Splash Guards (clear bra under the guards)
APR Version 2 Carbon Fiber Front Splitter
APR Carbon Fiber Radiator Shroud
Custom Carbon Fiber License Tag Frame (acrylic over tag and all fastners hidden)
Pipedreams Custom Painted Caps
Pipedreams Custom Painted Info Plate
Pipedreams Custom Painted Alternator Cover
Pipedreams Custom Painted Gas Gap
DSV Shift Boot
DSV Ebrake Boot
DSV Ebrake Handle
Lloyds ZR1 Mats (only used for shows, stock mats used for driving)
Lloyds ZR1 Cargo Mat with "USA Rocket" embroidry
Stainless Steel Akrapovic Exhaust with Titanium Tips Wrapped in Dry Carbon Fiber
Mild2Wild Exhaust Controller with Two Remotes
Ebony Vettebin (with 12v outlet) & Partition
Corvette StealthLink Battery Charger Connection
Custom Carbon Fiber Shift Knob with solid Polished Aluminum Shaft
(One off, made in my machine shop. Also have stock shift knob)
Latest Version 2 PAL, long cord routed to center console
Corvette Window Valet
Phoenix Performance Front Tow Eye (The receiver is a threaded steal section bolted to the frame. The tow hook can be installed through the front grill for towing onto a flatbed if required like the Mercedes and BMWs.)
Elite Engineering Dead Pedal
(Installed with a spare Plastic Dead Pedal Assembly, have the original stock plastic dead pedal)
White fog light lamps to match Xenon headlights
Switchback LED front turn signal bulbs (white when driving, flash yellow/white/yellow when turning)
Equipped with a LOJACK device, will transfer to new owner
Southern Car Parts Taillight Seals
Other Items:
Three Remotes, Each one in a Rubber Protector
Matching Die Cast Model
CTEK Battery Charger
Spare Stock Door Handles (can be used as Core for Painted ones)
Elite Engineering Wide Gas Pedal (not currently installed)
Modifications:
DSV Shift Boot
DSV Ebrake Boot
DSV Ebrake Handle
Other Items:
