Jistari
I have :
(2) B.F. Goodrich g-Force T/A KD 245/45 ZR 17 95Y (oem size front)
not less than 6/32 tread (New = 9/32 ).
(2) B.F. Goodrich g-Force T/A KD 275/40 ZR 18 99Y (oem size rear)
not less than 4/32 tread (New = 9/32 ).
They were on the car when I bought it, only reason I took them off was that I like to go on long trips and they were not run flats. The car drove very well with them (nice and quiet) and they stuck like glue.
The blurb on Tire Rack for this tire is :
The g-Force T/A KD features BFGoodrich's high-silica BlackTech tread compound molded into tires specifically developed for the left and right side of the vehicle. The g-Force T/A KD is the first BFGoodrich tire to feature an asymmetric tread pattern (with large, stable blocks to provide more outer shoulder contact area than almost any other street tire in history) which increases cornering traction and steering response, combined with directional water evacuation channels to help resist hydroplaning and enhance wet traction. The tire's structure includes twin steel belts reinforced by BFGoodrich's ETEC System (spirally wound nylon) that provide excellent strength, uniform ride quality, and Y-speed rated (186 mph) capability. And for handling control and feedback, g-Control sidewall inserts resist lateral deflection and allow the g-Force T/A KD tires to generate tremendous cornering force. Front $220 Rear $230 (new).
Pics follow:
Front tread
Rear tread
They are clean all around, I only found two small blemishes, which I'm sure don't amount to anything :
I took a pebble out of one spot, less than 1/32 deep, a surface thing, not a puncture (and obviously does not affect the tread block it's in, or the inside which would be about 15/32 away)
And I found a small (1/4 inch) tear, looks like just the surface, no penetration.
I only include them because I know how it is buying stuff online and I dont believe in surprises. Full disclosure = best way to go
Other than that, they look great.
I was asking $300 + shipping, I'm open for PM offers.
Pics follow:
Front tread
Rear tread
