hzl6cm
I have a 3849804 Holley 2818-1 Carb dated 533 (3rd week of March 1965) that I would sell for $100 plus shipping. As far as I know this would be correct for a 1965 350 and and 365 hp 327. It has the correct 4094 primary and 4099 secondary metering blocks and has a the complete original choke assembly with the clear plastic housing. The carb is complete but moisture has gotten in to it (while it was still bolted to the engine moisture got in to the jury rigged cold air intake while the car was sitting) and corroded the choke and throttle plates and some of the other stamped steel parts. The throttle plates are stuck and I haven't tried to free them since I didn't want to mess anything up. The throttle plates aren't in too bad of shape but the choke plate is pitted. Also, the small flat steel plate between the choke arm and the choke plate is corroded through. Below should be some pictures that I took this morning. This carb was installed on a 58, Corvette 283, with 64 heads that was installed in a '66 MGBGT in the early 70s. Since none of this car is original I am gong with an Edelbrock 600cfm carb so I don't need this one.
Kevin
Kevin
