eoseitz
Hey Everyone. I'm almost finished with my engine build and I'm needing to choose a carb. I'm leaning toward a 650 edelbrock to match my intake. Would a 650 be good or should I step up to a 700? My other question is about the distributor. I have a 74 corvette and I need an MSD tach drive (or knock off) to run my RPM gauge. However, the websites I'm viewing is saying it will only work on vehicles up to a 74. Is there anything different about the gear on the bottom that would make this not work in my setup? I've list full build details below.
Heads
1965 Chevy Double Hump 3890462
2.02 Intake 1.60 Exhaust 64 CC combustion chamber
Pistons
Unknown Brand….Stamped 0.30
Block
1982 LT9 350 Bored .030 over.
Rocker Arms
Brand:COMP Cams
Manufacturer's Part Number:17002-16
Part Type:Rocker Arms
Product Line:COMP Cams High Energy Die-Cast Aluminum Rocker Arms
Summit Racing Part Number:CCA-17002-16
UPC:036584215943
Rocker Arm Mounting Style:Stud
Rocker Arm Ratio:1.6
Rocker Arm Style:Full roller
Stud Size:3/8 in.
Shims Included:No
Rocker Arm Material:Aluminum
Self-Aligning:No
Rocker Arm Body Style:Standard
Rocker Arm Nut Style
olylock
Slot Style:Standard
Push Rod
Brand: Elgin
Pushrod Model Or Series: Heavy Duty
Year: SB Chevy
Engine: SB Chevy
Tube Diameter: 5/16"
Tube Wall: .075" Wall
Length: 7.8
Material: C1010
Heat Treated: Yes
Use With Guide Plates: Yes
Rocker Arm Studs
COMPETITION SCREW-IN ROCKER ARM STUDS
C.A.T Power part # RAS 3750
Comparable to Mr Gasket part # 1075
A 7/16"-14 tapped hole in the head is necessary for installation. Stock heads do not have threaded holes.
Top 3/8"-24 thread size (for rocker arm nut/polylock)
Bottom 7/16"-14 thread size
2-1/2" overall length
Hex base up - 1-3/4" long
Lifters
Brand:Sealed Power
Manufacturer's Part Number:HT-817
Part Type:Lifters
Product Line:Sealed Power Hydraulic Lifters
Summit Racing Part Number:SLP-HT-817
UPC:724956565054
Lifter Style:Hydraulic flat tappet
Lifter Link Bars Included:No
Link Bar:None
Lifter Outside Diameter (in):0.842 in.
Lifter Offset:None
Cam
Hi-Flow 1H
Erson E110421
RPM Range 2750-5750
Duration @ .050 Lift 228 deg
Valve Lift .472 in
Lobe Separation 108 deg
Advance 0 deg
Intake
Edelbrock 2701 Performer EPS
Heads
Pistons
Block
Rocker Arms
Brand:COMP Cams
UPC:036584215943
Stud Size:3/8 in.
Shims Included:No
Self-Aligning:No
Slot Style:Standard
Push Rod
Brand: Elgin
Year: SB Chevy
Engine: SB Chevy
Length: 7.8
Material: C1010
Heat Treated: Yes
Rocker Arm Studs
Lifters
Brand:Sealed Power
Part Type:Lifters
UPC:724956565054
Link Bar:None
Lifter Offset:None
Cam
Hi-Flow 1H
Erson E110421
RPM Range 2750-5750
Valve Lift .472 in
Advance 0 deg
Intake
