SSTibet
I need to understand some more about the fuel control valves.
1. I notice the gizmo on the fuel feed line, which is called the "schrader valve", and it looks like a small black knob from the outside. What is the function of this valve??? First time I hear a valve type like this? What is a "schrader valve" in general terms???
2. I also see the "fule pressure regulator" which is (a) connected to intake manifold vacuum and (b) is located on the fuel return line. How does the regulator function with the manifold vacuum?
Cheers all Corvette Lovers
