72Slydog
Need help from the experts to identify my fuel injectors. I have a 1972 corvette with a ZZ3 engine equipped with a 1990 TPI setup.
The engine has been modified and a custom chip installed in the ECM. Previous owner does not recall what type of injectors were programmed. Only clue I have are the numbers on the injector.
Appears to be a Lucas Domestic O-ring type injector with the numbers 621022, D1810AA and 2395 stamped on each injector. Does anyone have a clue what type of injectors these are?
