English Guy
Is replacing fuel injectors on L98 a job that requires any special tools,is this a really hard job to take on?Thanks for any advice.
JAKE AND VETTE079,thank you both for the advice.I recently changed fuel filter and I have used so called injector cleaner but willnot bother using it again,cheers
Brian.
At the risk of putting our 2 cents in, if at any time you decide that you would like to change injectors, we have a large inventory of "remanufactured" injectors, along with the "infamous" Bosch Design lll. We are offering a 10% discount on all products and services if you happen to be interested, and yes we do provide international shipping.
You can take a look at what we have a www.southbayfuelinjectors.com
If purchasing, type in discount code: M11119 at checkout.
If there is something that you are looking for that you do not see, please contact us.![]()
Yes, 19lb is the stock replacement, but the bosch lll's will be just fine also.
I just had my 89's injectors replaced using injectors I got from Jon at FIC.
TonyLong, Did you go with the IIs or IIIs? You link is to the II's. Looks like Jon has modified the IIIs to be the same length as the stock injectors. I was impressed with the spray pattern of the IIIs, which matched very close to the stock. Notice any improvements?
