I
Imran
Hey everyone,
Well, my fuel line is leaking on my 74. It's the main line from the tank to the fuel pump, it must have cracked a little when we installed the new gas tank. Anyway, I can't find the leak exactly, but it's SOMEWHERE around where the metal fuel line bends 90 degrees so it can travel down the length of the body to the front.
What are my options? Can I fix it while it's there? It's seemingly a hairline fracture, and it's BARELY leaking fuel. The fuel runs down the rubber hose, and then drips at the bottom. It's such a small leak that it drops maybe once every 20 seconds. However, it stinks up my garage unbelievably!
Can I seal the line somehow from the outside? Or what is my best option to replace the line? I don't necessarily need stock, because that's over a hundred bucks, and it looks like you have to remove the body to get to the line
Help please again
Imran - 74
Help please again
Imran - 74
