7
76L82
Talk about Friday the 13th!
I was into a 20 minute ride to work today on the Interstate...everything going well...until the car started to 'lurch' and 'lunge' as if it was running out of gas. I was running at about 3200 rpm and going about 67 mph when it all happened.
However, there was plenty of gas in it. So I lifted my foot off the gas pedal and coasted a bit. I put my foot back on the pedal and kept the car at about 60 mph around 2500 or so rpm. No lurching or lunging. Thinking it may have 'swallowed' something it didn't like, I pulled off the highway and headed to a gas station. I hit 2 traffic signals and the car seemed to be fine again...chalk it up to Friday the 13th gremlins!!
I filled it up with super premium and then got back on the road. Everything's going fine until I try to see if I can get it to do it again...sure enough, 3rd gear around 3200 rpm..the car starts to lurch and lunge again.
I drive it to work another 10 miles or so at low speeds...no problem...doesn't hiccup, sputter or anything. I pop the hood. All the plug wires are intact and where they need to be...no leaking fuel around the carb...hummmm.
I am wondering if there is a problem with the fuel system...accelerator pump, fuel pump ...or is this an ignition problem...distributor, coil, etc.
Of course the inevitable happens...on the way home from work I could swear it is now running rough, has lost a lot of power and dieseling when it never did...
Any thoughts? I have started to worry that I may have lost a cyclinder or something...
