fuel pressure help
geogolf
brookville pa.
1990 L98 coupe green
hey guys is there any way to get a little more fuel pres. i put on a set of slp runners, and did some porting work car [90 l98] does not want to run over 5200 rpm before it would go to 5500/5700 no prob. is it getting to much air /not enough fuel, is there a way to increase pres. on stock setup, or will i have to buy a adj. reg. or could there be something else wrong. went over intake and plenum with starting fluid no vacuum leaks any help is greatly appr.
you can ''shim'' the srping in the oem fpr but its a time consuming trial-and-error deal...or get higher flow rate injectors from a 94-96 buick roadmaster or lt 1 caprice at j-y (their a better unit than 90/l98 oem anyway
i assume you've already checked fuel pressure isn't falling off at 5200 under actual load condition
