ironmoo
Yesterday without warning the car would not start. Upon turning the key, no familiar whirring sound from the rear of the car just before starting.....
...and a dead gas gauge. No movement from the needle.
-Car is cranking fine.
-No gas up front at the injectors.
Today:
Replaced the Fuel Pump relay. Found the connectors covered with a black gooey grease. Cleaned up easy and connected to brand new relay.
-Checked/cleaned the rear harness connection at the tank.
-The fuse looks okay in the fusebox.
-Made sure I had gas in the tank. But did notice some small white-ish material floating as I did stirred up the bottom of the tank with the clear syphon hose.
Next step seems to be replacing the Fuel Pump.
Since the gas gauge is not working, I may clean all the lines and replace the filter just case a clog killed the pump.
Question:
Is there anything else that can kill the fuel pump electrically? Only thing replaced recently was a wiper-override switch and the car ran fine with it.
Am I missing something here?
The car is very relieable so the it just dying this way caught me off-guard. (But glad it was parked in the garage when it died!) :L
Thanks ahead for your thoughts!
-MOo!
Today:
Question:
-MOo!
