This problem only occurs when I first get into the car. If it does start, the check engine light is lit. If I turn off the key and listen for the fuel pump to turn off (just a few seconds), the car will start just fine. So,... Why does the fuel pump not turn on the first time I try to start it, AND, Is the fuel line draining when it sits but the system thinks there should be fuel pressure from the last time it was run. The car runs great after I turn it over 10 seconds which turns on the pump.
