Vette79
When I disconnect the inlet fuel line at the fuel pump it won't stop draining fuel from the tank. What is the procedure in replacing a fuel pump? I read the steps that the shop manual specifies and all it says is to disconnect the lines and replace then reconnect. Does it take a while for the fuel to drain or am I missing something like using a pair of vice grips to close off the line to replace fuel pump?
