Help! Fuel Pump
Rob82
New member
New Rochelle NY
1982 Corvette base Red
Hi have a 82 crossfire and I am have problems with the fuel pump. When I hook up the battery charger and put it on start boost the fuel pump will work and the car will run for a few hrs then when I shut it off and try starting the fuel pump will not come on until I hook the battery charger and set it to boost I already changed the fuel pump relay and that is not it I have a fuel pump ac delco that I will be putting in this weekend is there something I am missing as to why it will start only with the battery charger....
Welcome to CAC!!!
Enjoy!!!
have you checked you wiring?????
or perhaps a bad ground....
Hi Rob (?), welcome to the CAC!
What model fuel pump do you have? The original or did you go 84/85 yet?
When mine failed, the car even ran, but wouldn't take well to trying to accelerate at all; anything over 1500RPMs would make it die.
If it's still the original, i would swap it out for the newer style.
:w
Stefan
Are your connections onto your battery tight?
If they're not you will be getting a drop in voltage across these connections; which could affect a motors performance.
:w
Stefan
I just have a new AC Delco fuel pump that I will put in this weekend I am going to check all the grounds too... I heard that I can upgrade to a 85 fuel pump...
Yes they are tight I also put on new cables too but I will check all and see if they are all tight.... I will be working on it this weekend and see if I can get it to go..
