4
406shark
Hello,
I am going to redo my current fuel set-up for next season. My question is this...
I have a stock fuel tank in my '77 that is currently feeding a Carter electric fuel pump. It is hooked to the factory 3/8ths line. What I would like to do is add another fuel pump (hi volume/hi pressure type) that I can feed into a seperate fuel line for when I race. My thought was to run the two lines to a regulator, then into my Mighty Demon carb.
Does anyone know if it would work to add a fuel pickup point to the bottom of the factory tank to feed the added fuel supply? I realize that I will need to remove the bladder that is currently inside the tank. The bladder is starting to shrink up...it now only holds 14.1 gallons instead of the stated 17.0 gallon capacity.
The current Carter pump was working on the street, but at the track this season I was running it out of fuel at the top of 2nd gear. I have an extra new Carter (backup unit) that I thought I would install for normal driving, but install the new (hi volume/hi pressure unit) to only activate when racing. Any thoughts?
Any help would be appreciated.
Thanks, Jeff
Thanks, Jeff
