V
VETDRMS
I'm building a 406, and am having some difficulty on deciding on how to approach the bottom end while still fitting it into my budget. The block is a "509" 2 bolt, I have ARP studs for the mains, but am somewhat concerned about the strength. I should be at ~500/500 hp/tq.
These are the options i'm aware of, but not sure of which one to do.
1.) Check registers for proper alignment and just use studs with stock caps.
2.) Same as above, but machine block and caps and install locating dowels.
3.) Install support straps on the mains.
4.) Install steel caps
5.) Install Splayed Caps
4 and 5 are a bit out of the budget, but 1-3 are doable.
At this point I would like to go with 1, and if the registers aren't quite right, go ahead and install the dowels. I do not intend to run this motor over 6000 rpm, and will only see rpm's above 5500 for brief amounts of time. I will probably install the support strap over the rear main, as the 400 is kind of weak there.
Any help or clarification is welcome!
Thanks.
Thanks.
;worship
