S
sscam69
I need some help in determining what a blue and black wire hooked up to, what seems like a temp sensor, on the right head (right side if you were sitting in the car). The engine has been rebuilt and has a new pump, cleaned out radiator, new hoses, thermostat, timing is good. The point is everything is practicaly new but it is still reading hot. I just got the car from getting a true dual exhaust put on it. As I was driving it back from the shop, with no hood mind you, to the mechanic (so he could finish putting some new bushings in the rear suspension) the temp gauge was indicating it was at 220. Someone (rpound i believe) was enquiring about this and found that the gauge was reading 10 deg above what it actually was. I took the main street route, there was a lot of stop signs, lights and school zones. I figured it shouldn't overheat due to the fact that the hood was off and air should flow with ease through the radiator. The gauge was still climbing when i reached the mechanic.
My questions are
Is the gauge electrically run, or is does the heat from the wire have to travel to the gauge?
I need to know so i can either insulate the wire or get the gauge checked. The mechanic stated that if the engine overheated that the engine would be hard to crank. when i stopped with the mechanic i cranked it 3 times with out much hesitation.
does this blue and black wire have to do anything with the temp sensor.
Any HELP would be greatly appreciated!
p.s. Its a 79 L-82 thanx
My questions are
