Aug 29, 2010 #1 J jimbil208 Well-known member Joined Jun 28, 2010 Messages 254 Location pa Corvette 1982 collectors edition Did anyone have this problem? When I pulled the fuse for the ECM(to reset it)It was very hot to the touch. The fuse is by the battery.
Sep 4, 2010 Thread starter #2 J jimbil208 Well-known member Joined Jun 28, 2010 Messages 254 Location pa Corvette 1982 collectors edition Hot By the way,I replaced the fude holder,it was only rated for 5 amps,had a 20 amp fuse in it.
Sep 5, 2010 #3 P Peer81 Well-known member Joined May 21, 2003 Messages 2,497 Location Netherlands Corvette '81 Black Does a 82 ECM use more then 5 amps? A 20 amps fuse is nice for a mid sized amplifier but for an ECM? Greetings Peter
Sep 5, 2010 Thread starter #4 J jimbil208 Well-known member Joined Jun 28, 2010 Messages 254 Location pa Corvette 1982 collectors edition Hot Peter It calls for 20 amps. Besides if it wasn't drawing that much current,the 5 amp fuse holder wouldn't be hot. Thanks,Jim
Sep 6, 2010 #5 P Peer81 Well-known member Joined May 21, 2003 Messages 2,497 Location Netherlands Corvette '81 Black Oke, if it calls for a 20 amps fuse then that is what it is I didn't know a 82 ECM needed that much current. Greetings Peter
