The only tip I would offer is that since the car runs, run the gas out of it before dropping the tank. Usually the tank is being dropped due to a fuel pump being bad and it usually is full of fuel. You are lucky because you can empty it without the mess and hassle of siphoning or otherwise draining and dealing with the gas.
Since you don't have a gas gauge to know when it is empty, get a container that you can seal very well and fill it with gas. Have a funnel or whatever is necessary to put the gas from the container into the tank. Run the car empty, then put in enough gas from the container to get home.
To me getting the gas out of the tank and dealing with it is the worst part of the job of pulling any tank. But that's just me.
Good luck,
