...........FrankNo, a carb can't leak oil but if gas is slowly leaking, it will cause stains which can resemble oil leaks. The stain is actually residue left when the gas evaporates and if you've got those stains, you've got the gas smell too.tonyk72 said:I sort of clueless when it comes to mechanics...so is it possible for a carb to leak oil? Or is it just the gasket?
tonyk72 said:I checked around the carb today and looked around the intake and I found a pool of gas by the intake maifold bolt. Then I was lucky enough to see the gas actually drip from problem area...see attached pic...black arrows indicate where the gas was dripping from. I still have to track down exactly where the leak originates, at least I have a starting point now...
