I believe the 68-74 tanks should hold 18 gallons but this is one area that has long be debated.The 75-79? hada bladder inside the tank that will collapse from age and close off space in the tank. The early tanks have the sender in the tank bottom and the later tanks have it on top. Any chance someone switched them in the past? I have never tried this myself so I don't even know if they'll fit but a quick look at the tank bottom will tell.
Quantum is the place that makes then now so you can call them as well for info.
Lastly, if you're running a glass filter I would replace it with a steel fuel line and inline metal or aluminum filter. Those glass filters and rubber hoses are the cause of engine fires.
