T
tscott9330
Ok, on the 78 gas tank, there are 4 holes. 3 are in the metal collar where the cap screws into. The larger of the 3 is a feed line to the pump, the smaller is a return, and the third is a vent. There is another in the tank itself, but does not go all the way into the tank. It does not go through the plastic liner of the tank. Origionally there was a fitting of some type screwed in there, but I have misplaced that at some point.... Go figure, I lost a part. What does this 1/2 inch threaded hole do?
Tom
Tom
