81 Corvette said:
..... the problem then becomes, if you bump up your HP, at what point do you start spinning your tires at the line when you mash the gas, which tells me 3.54 is a good gear to have.
I guess i'm just biased since thats the gear i choose.
This is, by my estimate, what is wrong with the early OD transmissions:
1st gear is too low, OD is fairly-tall, and the gear-ratios are far apart.
Other than the 3.73s, my '82 is box-stock, and even with
IT'S pathetic Cross-Fire, it can spin the tires with ease in Low Gear, which is great if yer trying to impress "
High-school Harry" and the 17 year-old tenderonies.....
but on the 1-2 gear change, going from 3.06 to 1.63 ratios in the 700R4 is just too-much for the L-83 (
imagine what is was like BEFORE the 3.73s, with the OEM 2.87s.....):
it literally 'falls' on it's own face.
If ya make enough '
smoke', ala a stroker 383, a 406, or a ZZ502, it can '
pull' that big gear ratio/RPM drop with ease, but with that kind of torque, you wouldn't
need such low-1st gear/ tall OD ratios, resulting in the wide spacing between ratios.....
:crazy
The 'newer' Corvettes, with their computer-assisted high-tech fuel-injection systems, keep the engine making maximum power at all times, re-adjusting and re-calibrating several times per second:
that's almost impossible with an older Corvette, using a carb.....
I guess I'm just "used-to" driving cars with deep rear-gearing, and 'traditional'-type automatics (
THM350/400), with closer gear-ratios (
2.48, 1.48, 1:1) and a 'loose' converter.....
