Gear ratios...
  • Thread starter Thread starter VetterMan
V
VetterMan
Anyone else notice the slight gear ratio advantage the base C6 will have over the sport model C6 in 5th gear? Considering the engine is the same in both, the base should pull a bit quicker in fifth gear. Since terminal velocities will occur in 5th gear, will this effect the top speed between the two models? Hmmm...
C6 fifth gear ratio (:1):
base: 0.74
sport: 0.71
