BELOW IS THE RESPONSE I HAD FROM DEPT. OF TRANS., U.S. .THOUGH, THIS IS NOT THE QUESTION I HAVE ASKED, IT IS INFORMATIVE NONETHELESS. I MYSELF HAVE REQUESTED REDRESS TO MY SPECIFIC SITUATION.
Q; Are There Any Limitations on My Right to Have My Vehicle Remedied at No Charge?
A: Yes.
There is a limitation based on the age of the vehicle. In order to be
eligible for free remedy, the vehicle cannot be more than 10 years old on
the date the defect or non-compliance is determined. Under the law, the age
of the vehicle is calculated from the date of sale to the first purchaser.
For example, if a defect is found in 2003 and a recall ordered,
manufacturers are required to make the correction available at no charge
only to cars purchased new in 1994 through 2003. However, consumers should
realize that even though manufacturers are not obligated to remedy safety
defects in older cars, a safety problem may still exist. If you receive
notification of a defect on a vehicle older than 10 years, take the
responsibility to have your car repaired at your own expense. Eliminate any
unnecessary safety risks.
Also, if the manufacturer challenges the agency's final decision of a
safety defect, there is no obligation to remedy the defect while the case
is in court. If you decide to take your vehicle in for correction after the
agency's decision is made but before the case is finally decided and the
court decides that the defect is not safety-related, Federal law does not
require that the manufacturer reimburse you for the repair work. However,
if the court upholds NHTSA's final decision, you may be entitled to
reimbursement. Be sure to save all receipts and paperwork so that you can
prove the repairs were made.
A: Yes.
Jump..........we have a net
