firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
I working through the various things that need to be done...when the motor was removed and the exhaust was seperated from the exhaust manifold....well....you know.....two of the bolts broke....so I need to replace them...so while I am at it...I thought heck...if two can break now...what about when it goes back together, perhaps others can break....so might as well change them all....
Before I tried anything, I went out and bought some of that PB Blaster (special thanks to Larry/IH2LOSE and everyone else that chimed in on that thread) at local auto store. Sprayed it on exhaust manifolds and let it sit overnight...hit it again and let it sit again....both sides each time...
Tonight I put a pair of vice grips on the exhaust manifold that has that heat riser flapper thingy (those 3 bolts were not broken off and there was some clearance around all the bolts) and with my foot on the manifold grabbed the vice grips and low and behold the screw moved!!! Got it out....and then did the other two the same way....WOW was I amazed......now onto the second manifold.....
It doesn't have any little pockets like the first one did around the studs that would hold the PB and let it work its way in....nor are the threads on the backside as defined on this manifold as the first one.....this manifold also has the two broken off studs. One broke off pretty clean to the manifold, no option there but to drill that one out. Second one has a bit of a stud sticking up of about 1/2" to 3/4", my guess is that one will also be a candidate for drilling. I tried the vice grips on the remaining intact stud....and that sucker did not want to move...no matter what....so I sprayed that one with some more spray and will let it sit over night....but I am not optimistic that one is coming out with vice grips....it seemed to laugh at the vice grips....so....what is my best option???
1 - Try to get it out with vice grips? After more PB....
2 - Cut it off flush with a hacksaw and drill it out?
3 - Try to get it out with vice grips after hitting it with a propane torch?
4 - Other good solutions that have worked for you?
When I get the new bolts, should I run a tap down the holes to make sure the threads are cleaned up? or what else should I do?
Also, thought about sand blasting them while they were out and then putting that gray type of paint on them that cures when the motor is run....or other thoughts?
thanks for taking the time to read this and providing some insight...
Herb
Herb
