ugabuga
New member
Good Morning everyone an Happy Memorial Day Weekend.
I'm new to this forum and I'm looking for help.
Finally my c4 (96) was ready for the weekend! (not relay apparently).
After a major 3 days of work on the Optispark replacement , everything looked fine, engine was running like silk, making all the good noises that one would expect from a health LT1 engine! But last night, after a 50 or so miles drive the engine died while on idle from just a block of my house, it started right after and the died again, this time it was harder to start, but it did and I was able to park my baby in the garage. This morning , after hooking the car to the computer I’ve found 2 codes on stored on the car.
P0102 mass air flow circuitry low frequency and P0372 ICM 24x reference circuit missing pulses.
Now here is the strange part… when the key is on the “ON” position (engine not running) lots of strange noises are happening on the engine bay.
1. the air pump cycles on and off
2. fuel pump cycles on and off
3. noises that sound like an shot circuit of some kind.
Isn’t this curios?
If I clean the codes on the computer they come back (even if the engine is not running)
I’ve unplugged everything from the ignition system and the problem seems to occur only when the optispak harness is plugged in. (harness is in good shape and the terminals are clean.
What could have happened to the optspark to cause this weird problem? (Hope is not the PITA optspark!)
Open for Ideas, Suggestion, Miracles……
Isn’t this curios?
