PokerJoker
Hello all,
The car is running great after the engine swap, rebuild on the trans and new front suspension parts. ECM still working and no Check Engine Light
But now, drivers side window won't come down, door lock have never worked (since I've owned the car), but with this heat...I need to be able to roll the windows down to drive it...so...
I took off the door panel, and it looks like a mess and I don't know where to start.
1. Wire connector going to door lock switch is broken (gray wire is disconnected/or broken) whole connector looks pretty rough. The pins on the actual switch are very corroded. Pulled the connector off the actuator and jumped it. It seemed like it wanted to do something but would not unlock/lock the door.
2. The rod that comes out of the armrest is missing, so I've got one on the way...but I'm not sure what it connects to.
3. Tapped on the window motor with small hammer and it actually started to work, but not great...and only a few times before it quit again.
4. Reached down into the bottom of the door and found a broken regulator gear spring...center broken out. Can this spring be replaced without removing the regulator?
5. Outside door handle has a crack in it, so I want to replace it.
Where to start first or does it even matter?
Thanks for any advice.
Jeff
Jeff
