S
SHVETTE98
After two and a half years of owning my 98, I traded it in yesterday. I had finally had enough with it, the column lock problem, the leaking battery acid that ruined my HVAC lines (twice), the wheel sensors being replaced, the throttle sensor going out, the warped front rotors, and the squeeky sway bar bushings. All this for a car I put 17,000 miles on. Thanks to all on this website, I found more useful information here than I did anywhere else. Good luck to all of you and I hope your Vette doesn't disappoint you as mine did me.
