and I am trying to replace the fluid. I bought 2 units of posi fluid and 2 units of diff fluid. I jacked up the left rear and crawled under to have a look. All I saw was spring and skid plate. Above that, after some wiggling around, I saw the inspection /fill hole for the diff. I did not see a drain hole. I made a run to the local Chevy dealer to talk to their mechanics. I was told that there was no drain plug on a 78. My choices were to either siphon the fluid out (not what they would do) or take off the rear cover and drain it (which they would do). I'm thinking maybe loosening up the bolts enough to drain the fluid, rather than remove the whole plate. Since I have no access to a hoist, I would have to drive it up on a set of ramps, and then jack up the back end enough to place some ramps under the tires. I'm not even sure that is possible. I don't know if my jack would get under it, and I'm not sure my jack would get it high enough. Could be a real PITA. Should I just take it somewhere?
Is there an easier way? Any "gotchas" that I need to be prepared for? Is the rear cover just that; a cover? Or is the pumpkin attached to it?
