Grand Sport Calipers on older C4
norwegianvette
Norway
1993 Aqua Convertible
Hi Folks.
Will the GS Calipers fit straight on a 1993 front or do i need some extras?
Best regards,
Steve
To put GS calipers on a 93, in the front, you need rotors, caliper mounting brackets and calipers. In the rear, you need just calipers.
Also, you need bolt torque info. Be advised that several years of service manuals misprint the rear torque as the front which, of course, can lead to damage. I'm on a road trip right now w/o access to my service data, but maybe "c4c5 Specialist" can post the info.
So GS calipers fit behind sawblades - fantastic, just what I was looking for.
Do you happen to know the thickness of the GS rotor? I have aftermarket two-piece rotors with Brembo 6 pot calipers and I want to put sawblades back on.
From what I'm reading you want to go back to factory wheels without the Brembo setup?
tcxd40
tcxd40
Correct. I want to put sawblades back on the car but they won't fit with the Brembos. I wanted to know if GS calipers would fit with sawblades or if I needed J55s. Sounds like GS calipers fit!
Yes they do. I have already the Z07 package which has the J55 brakes. I liked the GS calipers which are much nicer than the factory calipers used with the J55 setup. Keep in mind that the Z07 comes with 9.5x 17 on all four corners.
tcxd40
